i thought you were serious about this? you shouldn't even bother putting a wastegate in.....audifreakjim wrote: I need to figure out where I'm headed with boost control first.
birdmanmt
85S2
Corey
It's from a Toyota MR2, Mk1 although the pump from the Mk2 is almost the same. It has a code SW20, which I think is the critical bit.
I am going through the same conversion on a couple of ur quattro's. What car are you fitting it on? If it has the hydraulic servo assit then you will need to convert to a vaccuum brake servo also as this pump won't beable to supply both steering and brakes.
Price is dependant on your local salvage yard
85S2
I have a Audi 90 Typ85, called 4000 in the states i think. I have mounted the stock 20v powersteering-pump with a modified holder, but the space for the Intake-Manifold is less with it. My car has a pneumatical Brake-Assistant (dont know how its called in english?).
Here you can see some pics (will be updated): http://mxbikes.de/querlenker/forum/viewtopic.php?t=22
A little update, the car runs, but I had a small issue with the check valve that feeds the head oil so it only ran for 15 seconds or so. So while I'm waiting for the new one which should be here Wed, here's some pretty unexciting pics
Breather. If you want to know what the oil sep. is, look through my website under 20v conversion.
Freeze plug mod, 12mm compression to pipe to AN. :woowoo:
Front cross member.
Front cross member.
olsonjus
JShadzi
We're finding its an issue with the main studs, you have to be careful installing the one above the check valve, we're going to have to spec a shorter stud for this, looks like to be safe pull the check valve, install and TQ the main studs, then reinstall the check valve.olsonjus wrote:Very cool. You are making some really good progress on it
So what is this deal with the checkvalves? Javad and now you? Is it a must replace when rebuilding?
Regards,
Justin
JShadzi
Now that is the fiddlesticking spirit 8)audifreakjim wrote:Not usually, but in perfecting the main stud install we realized that the hole for the mains is threaded into this oil galley. If you install the stud too deep it will crush the check valve. It's all in the name of progress, now we know what needs to be done in the future.
olsonjus
JShadzi
schweet 8) Yea, can't wait to see your beast on the road Justin, you're giving me 42R envy, soon enough...olsonjus wrote:Good to know. Atleast there's a solution to it all. I can't wait to get my motor to the machine shop and my extra 7A head down to javad for work. The west coast is going to have some very cool audis. Never Mind it all ready does
What would a motor install be without at LEAST one bolt requiring no less than an hour to R&R?
:woowoo:
:woowoo:
JShadzi
Wizard-of-OD
this isnt an issue with the 4 cyl blocks is it?JShadzi wrote:We're finding its an issue with the main studs, you have to be careful installing the one above the check valve, we're going to have to spec a shorter stud for this, looks like to be safe pull the check valve, install and TQ the main studs, then reinstall the check valve.
WAUG0806
Toxcheap
It runs! And damn well I might add.
http://mswanson.com/~jgreen/videos/20vtstart.3gp
Man this thing is smooth, no vibration, sounds just sick, and revs ohh soo easy!
Here's some pics of it pretty much ready to go. I'll be taking it out for a spin tomorrow!
