I asked for forgiveness for the carnage that was about to unfold and then got down to business. Still some good parts on it. Parking brake still worked flawlesly. When I saw a factory fog lamp switch on the cluster trim my face lit up and I ran to the front only to be disappointed.derracuda wrote:A moment of silence please
Dan's S8K...Strut towers gone :)
Re: Dan's 40V V8 4000 In Car Video
Dan
1984 Ur quattro
1987.5 Coupe GT Special Build
1984 Ur quattro
nismo
I wish I knew where to get clean 4kq's. Derek apparently hasn't shared the secret source of his 4kq goodness!
Eric
Eric
all of his and mine have come from craigslist.
Dan
1984 Ur quattro
1984 Ur quattro
Re: Dan's 40V V8 4000 Something in the mail
Got a box in the mail today...
Gonna try to get it in today and make an "after" video.
Dan
1984 Ur quattro
1984 Ur quattro
a_CQ
That's interesting. The idea is that it's removable, relatively easy?
oldsklaudidub
Re: Dan's 40V V8 4000 More Pics/Video
Big screen, surround sound, and popcorn in hand.40v4kq wrote:
Link to video
This film should win an Oscar, best co-star actor Dan, best lead actor Audi 4kq 4.2, and best supporting actor Derek.
LMAO Cory! Makes me happy to see how much you like that video. There are more, and better ones to come. I've got this thing goin up to 7k RPM already. Once it's as street-legal as I can make it i'll go and get some high rpm gear-rowing footage for you (and everyone else) to enjoy.
@ Petar. Yep, and Yep. I had to slide it into my flex pipe since the 3" section of aluminum tube after the flex pipe wasnt long enough for it to slide all the way in. It was acually a nice snug fit too. First sound check revealed that it's still too loud, but the insert comes with two weld on discs that look to me like freeze plugs for a domestic engine. One already has a hole drilled into it and the other is undrilled. The idea is that you can tack weld the caps onto the front end of the insert to quiet it down more. Start with the pre-drilled one and if it's not to your liking you can put the solid one on instead or drill it to your liking.
Dan
1984 Ur quattro
1984 Ur quattro
Re: Dan's 40V V8 4000 CC exhaust insert
Heres what it sounds like with the insert installed. It's still too loud so i'm gonna pop it out and weld on one of the caps and see what that does.
BTW, thats the neighbors stupid dogs yipping, they need to be run over.
Link to video
Link to video
Dan
1984 Ur quattro
1984 Ur quattro
OK, so what i did now is remove the insert and weld on the front cap that they call the "restrictor" and throw it back in. It's a bit quiter and more rumbly/less perky. There is even another cap i could weld on for maximum effect but I think this will work for now.
Heres a video for comparison with the one above. Even in the videos you can hear the difference...
Link to video
Link to video
Dan
1984 Ur quattro
1984 Ur quattro
oldsklaudidub
I do not hear a dog, not even a rat if you want to call it that. All I hear is fear.40v4kq wrote:Heres what it sounds like with the insert installed. It's still too loud so i'm gonna pop it out and weld on one of the caps and see what that does.
"Thorny: You smell something, Rabbit?
Rabbit: *sniff sniff* ... Fear."
Re: Dan's 40V V8 4000 another vid
Sounds freakin great Dan! Nice work!
I like the second vid the best so far
Corey, is there a trophy for our roles in this film? If so, I'm not welding them up....
man I like that crisp cranking. Glad we used 2/0 cable
Cory, tomorrow i'm gonna do my best to make you a vid you can really enjoy with a big screen, surround sound, and popcorn
I'm talkin 1080P and 7000RPM
I'm also gonna see if I can find my lisence plate for the back of my car to make it street-legal-ish.
Ben, the torch has been passed to you. It's now your turn to dazzle us with fantastic exhaust noises.
Derek, It was a good choice. Now I just need to install a circuit breaker at the battery so I dont have any catostrophic melt downs.
Dan
1984 Ur quattro
1984 Ur quattro
oldsklaudidub
There's a beverage of your choice waiting for you in May at Carlisle. Time for a road trip with the family.derracuda wrote:I like the second vid the best so far![]()
oldsklaudidub
Does it come with commentary like Allan McNish's lap around LeMans?40v4kq wrote:Corey, tomorrow i'm gonna do my best to make you a vid you can really enjoy with a big screen, surround sound, and popcornI'm talkin 1080P and 7000RPM
Challenge accepted.40v4kq wrote:Ben, the torch has been passed to you. It's now your turn to dazzle us with fantastic exhaust noises.
just give me a few months.
Corey, the cars exhaust will be doing all the commentary. It's hard to talk into a camera mounted on the back of the car.
Ben, you can have as many months as you need, but be warned that i'm gonna start asking if its done yet after only a couple days.
Dan
1984 Ur quattro
1984 Ur quattro
OOOOGT
Sound great!
- speeding-g60
thats it. i MUST do a V8 in the next project car. MUST.
Well, I am unable to make a good video today since I cant find a lisence plate for my car :( Gonna keep looking, it has to be here somewhere.
Dan
1984 Ur quattro
1984 Ur quattro
Dude, find that crap already!
It seems to be MIA. And more bad news...The trans in my GLI is crapping out on me. Started making a bad clicking noise on deceleration. Turns out its coming from the diff. The ring gear must be coming off of the carrier. Stupid rivets, why couldn't they have used bolts like every normal car maker?extreme90path wrote:Dude, find that crap already!
Dan
1984 Ur quattro
1984 Ur quattro
It's just an excuse to DD the V8 4kq.
Just go get yourself a temp!
Um, do to the circumstances of the previously mentioned engine swap on this vehicle california says GITFO of california, do not pass go, do not collect 200 dollars, do not pass smog, and do not get registration. So for me to get a temp i would have to drive approximately 300 miles to go to the correct DMV for said temp. In which case I apparently need replacement plates since I have lost mine. But dont worry, I got scooby-doo on the case and it should be handled in a couple weeks. I could deal with the DD part though, i'm only 6 minutes/4 miles from my work so even with high gas prices i should be fine if i can keep my foot out of the floor which is not possible for me.extreme90path wrote:It's just an excuse to DD the V8 4kq.Just go get yourself a temp!
Dan
1984 Ur quattro
1984 Ur quattro
