derracuda
Post by derracuda »
WOMBAT wrote:now don't go blamin' that stretchin crap on me! I had to to make the wheels fit :P That motor is looking great though!
it's all your fault buddy ;) i can't not stretch!! :P
mmmm, ronal goodness....
gonna have room for some killer brakes ;) plus! i can now finally lower the car!
Europrice
Post by Europrice »
OMG Ebay header will blows up yo motorz!
Looking good Derek!
Highlander
Post by Highlander »
Derek,
As usual, looking bloody brilliant.
Keep up the good work.
I managed to put 40kms on my urq today.
Nearly there.
Cheers,
Craig.
You are going to love those Dunlops. They run wide and I love the handling so far. They grip like mad.
:woowoo: :woowoo: looking sweet D!
keep it up
derrish_vulf
Post by derrish_vulf »
That intercooler is INSANE!!!
Keep at it man!!
WAUG0806
Post by WAUG0806 »
kinda feeling deja vu looking at the pix... noice werke!
Longitudinal
Post by Longitudinal »
cuatrokoop wrote:Air density certainly affects how it behaves Jonathan. You affect the Reynolds number with density, which affects the boundary layer/laminar flow/turbulent flow. This is making me want to get my old text books out and dust my brain off.
OK. Thanks for the correction. So density changes how the air flows, but what about my idea of the only change being density, versus the air being "pushed" in instead of "pulled?" I still think the air is being "pulled" regardless of density. Wrong again?
cuatrokoop
Post by cuatrokoop »
It's all driven by pressure differences. You lower the pressure on one side, you create movement as the system tries to equalize (high pressure expands into the low pressure region). So, you are always moving the air from the high pressure region to the low pressure region. A piston does the same thing on the intake stroke. So the flow bench works best in replicating a NA engine rather than a forced induction engine, but you can use it to check pressures at the inlet and outlet(s) to get a better idea of what is happening inside, if you have a good balanced flow, etc. So no, not really wrong again...
derracuda
Post by derracuda »
Audilard wrote:You are going to love those Dunlops. They run wide and I love the handling so far. They grip like mad.
funny you should mention this. my tires showed up today...here are some conclusive measurements.
falken azenis RT-615 235/40/17 measures out 8.5" on the tread width, 9.25" total width. height 24.25"
dunlop Direzza star spec in 215/40/17 measures out 8.5" on the tread width, 9.25" total width. height 23.25"
:D i wanted 235mm width tires that were about an inch shorter... whoo hoo!!
i dont wanna be a douche or anything. but im just gonna throw this out there...
if you wanna keep under hood temps down, why dont you header wrap the header and downpipe, plus do the heatshield...??
derracuda
Post by derracuda »
header wrap tends to destroy things when it comes to turbo temps.... it keep too much heat in and crystalizes the metal. it's better to have an air gap around the pipes so they don't retain too much heat.
derracuda wrote:header wrap tends to destroy things when it comes to turbo temps.... it keep too much heat in and crystalizes the metal. it's better to have an air gap around the pipes so they don't retain too much heat.
:stupid:
and that is something I did not know... right on..
Toxcheap
Post by Toxcheap »
:stupid:
I want to see this one on myth busters.
My exhaust manifolds wrapped, bagged with reflective heat stuff too. That goes for my turbo too. My downpipe is just wrapped, it's all been like that for 11 years now!! I may not have a big turbo, but I can guarantee that K24 turbo at 26psi running super lean on race fuel has seen EGT's no big turbo guy would chance his motor on
derracuda
Post by derracuda »
Toxcheap wrote:
:stupid:
there's always a lucky one :) my dad has told me of numerous old buick turbo v6's and how the original ones had the manifolds and cross over pipes wrapped/covered, and they just crystalized and would completely fall apart. not to say that audi probably used a better alloy in casting their EM's, but still.
DP wrapping i don't think has ever caused a problem, but i know i've read it on here a few times about guys with headers or whatever that have really taken a beating from being really wrapped up. if mythbusters would do it, i would applaud them, but it would mean they are super desperate for a show :P, and they would need to dyno engines under a load for like... weeks straight :lol:
Toxcheap wrote: I may not have a big turbo, but I can guarantee that K24 turbo at 26psi running super lean on race fuel has seen EGT's no big turbo guy would chance his motor on
hahaah i dont doubt it
a_CQ
Post by a_CQ »
Derek, the tire measurements, were they both off the wheels? Or if mounted, were they mounted on same wheels?
derracuda
Post by derracuda »
a_CQ wrote:Derek, the tire measurements, were they both off the wheels? Or if mounted, were they mounted on same wheels?
the 235 is mounted on an 8" rim, the 215 is unmounted, but will be mounted on an 8.5" rim. i measured bead to bead on the tire just sitting there, and it's 8.25" from the outer sides of the bead, so almost where it would sit on an 8.5" rim.
either way, the actual tread contact patch doesn't change so much with mounting tired on a narrow or wide rim (unless you are on a really skinny rim and it pooches the tire up). i will measure the 215 once it's on the rim for 100% measurements.
chapel
Post by chapel »
What valve cover is that? 7A?
cuatrokoop
Yes...
chapel
Post by chapel »
thought so
those bolt right onto an AAN with LS2 coils without any issues?
derracuda
Post by derracuda »
chapel wrote:thought so
what part of LS2 coils screams OEM audi to you? :P i have no idea if they'll bolt up "no problem", but my guess is they'll stick out and look kinda ugly.
chapel
Post by chapel »
what will stick out?
the LS2 coils use standard plug wires. the coils are mounted on the firewall.
chapel wrote:what will stick out?
shoudl work fine, its just a plug wire sticking out the hole like most other setups
