95audis6
Re: Taco's 4KTQ 20vt Swap: Project Red Baron - Pics of Damag
Post by 95audis6 »
just put a 20v in it. your going to end up there anyways lol
Repaair
Re: Taco's 4KTQ 20vt Swap: Project Red Baron - Bent valves..
Post by Repaair »
AngryTaco wrote:Damage $$$ is now known.
WIthout the machine work on the EM and Ceramic coat, I will be into the fix about $230-250.
Add $200 for machine work and Ceramic coat (optional).
Throw a used head on there to get it running, then port and rebuild the old head.
You won't be very happy if you slap two exhaust valves in and you find another one leaking and shot valve guides.
Somebody on here has a cheap MC head.
40v4kq
Post by 40v4kq »
That head he just pulled off was already rebuilt and ported.
Jared, just to be sure you dont have any more bent valves pull them all out and get some lapping compund and do a light lap on all the other valves so you can see if the are contacting the seats properly. That will show you for certain if you have any other bent valves.
Dan
1984 Ur quattro
1987.5 Coupe GT Special Build
95audis6 wrote:just put a 20v in it. your going to end up there anyways lol
Thought about it but Ill do a 20vt swap on another 4kq. Not this one though
Im with dan on this one. MAKE SURE you dont have any other bent valves. Also, are you having new guides put in the one that had the bent valves?
Nice score on the MC2 pistons!
The exhaust valve guides are all new. If there is excessive play then yes, they will be changed out. Talking to ceramic coater tomorrow to see if his stuff will work on piston crowns and chambers
On a side note, ordered a rod bearing set. Rockauto is having a closeout on Beck/Arnley rod bearing set standard size. Only $4.11!!
Re: Taco's 4KTQ 20vt Swap: Project Red Baron - MORE POWAH TI
Guess who scored MC2 pistons in excellent shape for $35?!?! They were even nice enough to give me the rods for free!
Before
After. The gasket blends in on the left making it look like I didnt fully port it. Trust me...I did :)
HUGE EXHAUST PORTS NOW!!!
Just an idea of how much material is removed. Add about another 50% of that and you get what I did.
:( Fix me.......
Hammer it out man! You will be up and running in no time.
Whole lot of materiel to come out of the exhaust ports, isn't there. I cant believe touching didn't do that when you did the intake ports.
ordered piston rings and flex hone today. Hopefully everything shows up by thursday
valves arrived today and picked up all consumables. Just waiting on hone tool and piston rings to arrive
Car is going back together this weekend. Have all parts to put it back together. New rings, MC2 pistons, rod bearings, trued and ceramic coated exhaust, new exhaust valves, hone tool, and....THE CAM
Get it done!!!
Got my ceramic coated EM. ITS SO PRETTTTTTTTTTTTTTYYYY
Hopefully I can grind out the car tomorrow and have it running. We shall see. Gotta pick up cheap oil to break in new rings.....100miles after my $55 german oil change..................................good thing I have clean buckets and bags to store it :)
40v4kq
Post by 40v4kq »
Pics? And what ever happened to piston and head coatings?
Dan
1984 Ur quattro
All but 1 piston is installed....bottem end will be done tomorrow night....managed to break an oil control ring somehow upon installation into the cylinder......
But other than that, everything is going together awesome.
Head is fixed
Putting Rings on MC2 pistons
Done yet? :P
Should be hauling ass this weekend
40v4kq wrote:Pics? And what ever happened to piston and head coatings?
Ended up being too expensive. It was gonna be another $250 for the head and pistons. I dont think it would be worth it in the long run on this motor. The Dodge however....
Exhaust Manifold is ported and done properly
Looking good! I hope the coating doesnt mess with the gasket for the turbo.
Theres no coating where the gaskets go. Made sure of that when I dropped it off
mounty
Post by mounty »
looks like progress.... doing good.
