Stock are pretty squishy but the stiffer rubber versions still don't seem all that stiff
Re: 1.9 TDI into 90q: Running
Posted: Thu Jun 11, 2015 11:04 pm
When I used the stock s4/s6 rubber it was brutal and they ripped apart after about 3500km
Posted: Fri Jun 12, 2015 7:41 am
by dana
interesting...was your TDI on a stock turbo?
I think Rich was using stock mounts without issue, I'll need to review his thread.
Posted: Mon Jun 15, 2015 8:36 am
by WOMBAT
Dana doesn't drive his cars hard, stock mounts will be fine.
Posted: Mon Jun 15, 2015 8:53 am
by dana
clutch dumps every day!
Posted: Mon Jun 15, 2015 8:55 am
by dana
WOMBAT wrote:Dana doesn't drive his cars hard, stock mounts will be fine.
i like to take it easy, and my daily commute is pretty forgiving.
Posted: Mon Jun 15, 2015 9:15 am
by DE80q
at least now I understand wanting the quattro so badly!
Posted: Mon Jun 15, 2015 9:17 am
by dana
DE80q wrote: at least now I understand wanting the quattro so badly!
its pretty much a necessity 6 months out of the year!
Posted: Mon Jun 15, 2015 1:26 pm
Hope you have a belly pan!
Er... wait.
Hope you don't, and feel like making some out of aluminum and selling them to folks like me.
Posted: Mon Jun 15, 2015 1:55 pm
by dana
PRY4SNO wrote:Hope you have a belly pan!
Er... wait.
my mk4 in the video did not....and I ended up doing this later this spring.
The 90 has the factory belly pan, but really with AWD i'll be able to go much slower up that hill during mud season and should be able to get by 99% of the time. With Front Wheel Fail, I have to keep the speed up to make the climb and thats what does the damage.
Posted: Mon Jun 15, 2015 2:00 pm
Shitty! At least both the sump and belly pan are easily enough found at a wrecker for a mk4.
If you ever make an aluminum b3/b4 pan, I'll buy one!
Posted: Mon Jun 15, 2015 2:23 pm
by dana
PRY4SNO wrote:Shitty! At least both the sump and belly pan are easily enough found at a wrecker for a mk4.
It actually might not be too hard, especially since I have the stock plastic stuff to model after.
The mk4 pans are $49 brand new! I guess they sell a few of those.
Posted: Mon Jun 15, 2015 2:27 pm
dana wrote:It actually might not be too hard, especially since I have the stock plastic stuff to model after.
Exactly my thoughts... you should do it! You know, for the community
Posted: Fri Jul 17, 2015 6:18 pm
by scubagli
Rich is using stock 4k diesel mounts. So you driving it?
Posted: Mon Jul 20, 2015 7:09 am
by dana
not driving yet, but engine bay is getting close to being ready for final wiring harness build. I've been getting pretty anal about the crossmember i built for the intercooler and radiator. Also, the piping is taking me a long time since I am trying to make it look decent. I spend a bunch of time and money on some real tool boxes and i build a nice new welding table.
Getting back into the car this week to finalize charge piping and then button up engine bay so i can build my harness to lay in it correctly.
Posted: Mon Jul 20, 2015 8:47 pm
by scubagli
Sweet, I need to buckle down on the 4k, just bought a multifunction welder, ac/dc tig stick and plasma in one unit. That should help...
Posted: Tue Jul 21, 2015 7:16 am
by dana
nice! that sounds excellent. Plasma and TIG would step my fabrication game up significantly! Thats a ways off in the future, since I just got real toolboxes and workbench for the first time.
Posted: Thu Jul 23, 2015 6:57 am
by dana
a little more progress. Been working on this regularly, but progress is slow. I think I'm getting more anal every time I build a new car, and its taking me way longer to perform simple tasks like charge piping, and engine bay layout. I'm finding it hard to make a TDI look like it belongs in this car.
got some used tool boxes and build a new steel welding/fab table.
I needed to get the factory air temp sensor into the piping, post intercooler. The factory bung is plastic, so i replicated it out of steel. Got some DOM tubing that was just about 1" I.D. and replicated the factory plastic bung out of steel using a grinder to match pipe profile and a cutoff wheel to cut the clip groves. Works well, not too pretty, but its hidden in the car anyway.
Charge piping in progress
airbox adapter made from an old winch plate:
Then I drilled a hole that is the right size for the sensor portion to fit into the airstream, but small enough to retain the sensor on the outside of the pipe.
the final product
Charge piping complete minus a couple 1/8 npt bungs i need to add to the charge piping for boost gauge, ecu and n75 connections.
Posted: Thu Jul 23, 2015 7:08 am
by DE80q
Looking great! I think this will be my next swap.
Posted: Thu Jul 23, 2015 7:14 am
by dana
DE80q wrote:Looking great! I think this will be my next swap.
i hope its worth it. I'm glad that Rich has a running car and is loving it, definitely helps with the motivation. Its really not that straight forward of a swap. I did a 20vt swap in 2 days, going from a running daily 7a to a running daily 3b, 48 hours! This damn swap is taking me forever.
Re: 1.9 TDI into 90q: Now actually turbocharged
Posted: Fri Jul 24, 2015 6:34 pm
by scubagli
Lol yeah it isn't direct.
Posted: Fri Jul 24, 2015 9:35 pm
Wow, love the airbox adaptation, looks killer!
Posted: Sat Jul 25, 2015 8:02 am
Looks fuggin awesome Dana. Charge piping looks great. Mine was SO ghetto in comparison.
To answer your question way back when, yes my alh was stock turbo.
Posted: Mon Jul 27, 2015 9:09 am
by dana
thanks guys! the charge piping has taken me a long time! Way longer than it should, but i think it came out well.
now its starting to look like a real engine bay again!
Intercooler and radiator crossmember is complete. You can't really tell, but there is some framework that the radiator sits on and the intercooler mounts to. It ties the whole front end together (kind of like the b5 cars) so you can take the entire assembly off the car in one piece. Should make servicing pretty easy.
there is so little room in there for a fan, i had no choice but to direct mount a slim fan. I lined the back of it with foam and made some backing plates to spread the load out to the edges of the radiator. It is very solid now, and I think will be no problem unless I crash into something.
you can see my reinforced motor mount here
added some boost fittings for boost gauge, ecu and n75
MFTS adapter made. A bit ugly, but looks good installed.
all the coolant piping and charge piping is finally fitted!
I was able to use 95% oem stuff.
-top hose is OEM 2.0 audi 80 with the oil cooler connection cut out and replaced with my coolant sensor bung.
-bottom hose is the stock audi 90 20v top hose cut to fit
-the rest of the stuff is a mix of the OEM tdi stuff and b5 a4 hoses.
Posted: Mon Jul 27, 2015 12:20 pm
I just finished doing an aluminum version of that using the factory bungs from an old coolant flange. Yours looks great, welding old oil soaked cast aluminum, yeah..
