a4kquattro wrote:No blue pills involved though!
Better to keep it "natural" <snip tasteless comment> :bump:
Toxcheap wrote:Marc in it's final resting place did the subframe clear ok with just the removal of the fins? I didn't actually look I just rememer it was close.
Alloutofdonuts wrote:a4kquattro wrote:So now the question: Will the 3.6 brackets bolt onto the 4.2 block?
The drivers side looks right to me, can't tell with the pass. side. You probably have them already but if not I gots a pair from my 3.6 you can use if you want 'em.
billzcat1 wrote:Looking good! You are going about the swap much the same way I did with the mount construction and oil cooler delete. You should see what is left of the oil cooler casting! I of course kept the alternator mount and spent about 30 minutes on the mill and another 2 hours with a file to make it shaped like it came that way.
About the oil cooler delete - its actually a good thing its gone - the plastic water nipple towards the front of the block is a very common failure item and its a time consuming, inconvenient repair. Very expensive for the A8 owners who always go to the dealer for service.
I got a variety of parts from Summit to facilitate the remote filter, cooler, and thermostatic control. I personally chose an RX7 oil cooler unit which is quite huge. It has a thermostatic control built in, but it is a very small passage so I blocked it to use an external thermostat.
I picked the 2 filter mount because the V8s traditionally have a large/long filter and this will allow using 2 of the shorter/cheaper standard filters and still have the same flow across the element as the tallboy the PT/ABH come with.billzcat1 wrote:Whaddya know I have the same exact 2-filter mount and thermostatI picked the 2 filter mount because the V8s traditionally have a large/long filter and this will allow using 2 of the shorter/cheaper standard filters and still have the same flow across the element as the tallboy the PT/ABH come with.
