Audi 200 20v Avant - Shed the 18 year old boy:)
Re: Audi 200 20v Avant - Shed the 18 year old boy:)
Can you give an explanation on how you fit the c4 climate controls?
AudiQuattros
Post by AudiQuattros »
loxxrider wrote:Can you give an explanation on how you fit the c4 climate controls?
I have the whole climate and from 45 of the body. It needs a good electrician who knows how to read wiring diagrams. and tubes, air conditioners are native.
Dmitry
OK, so the wiring will be difficult, but you say the tubes, flaps, valves, and those things are still from the 200?
AudiQuattros
loxxrider wrote:OK, so the wiring will be difficult, but you say the tubes, flaps, valves, and those things are still from the 200?
it is necessary to choose the place. and put. I have air-conditioning is not connected. generally.
Dmitry
Can you say it again? Maybe with different wording? The translation didn't work very well. Maybe you can try to translate it directly into german. I have read your posts on a German forum and it is much easier to understand there :)
AudiQuattros
loxxrider wrote:Can you say it again? Maybe with different wording? The translation didn't work very well. Maybe you can try to translate it directly into german. I have read your posts on a German forum and it is much easier to understand there :)
Надо по месту все подбирать. Самое сложное это проводку подключить . От 45 кузова.
Трубки кондиционера останутся родные.
Dmitry
Thank you
AudiQuattros
Переклеил заднюю левую форточку, вода через нее протекала.
Продал клубню свои перед тормоза.
Купил тормоза 8 поршней от R8/RS6/RS4. 365мм.
Поговорил с людьми и пришел к выводу что буду после зимы ставить абс снова. От 45 кузова.
Ян мне впаял диод в генератор :dance: :nr: . Теперь Вольтаж на генераторе 14.3, На аккуме 14.0, на приборке 14( было на горячую раньше 12,5 примерно) . Вентилятор включается без просадок теперь :)
Лампочки и все остальное заработало куда лучше!
Так же заказал новое водительское стекло зеленое. Надоели царапины.
Dmitry
2.5TYPE44
Post by 2.5TYPE44 »
Dimitri, I need one of those headlight height adjusters switch that you have....
and what about those clear headlight lenses?....
Nice job. I am interested in the diode? you used for the alternator. I think I have heard of this being done before.
AudiQuattros
2.5TYPE44 wrote:Dimitri, I need one of those headlight height adjusters switch that you have....
Leveling Headlights?
Dmitry
AudiQuattros
loxxrider wrote:Nice job. I am interested in the diode? you used for the alternator. I think I have heard of this being done before.
all the problems with electricity?) Yang, a blue Avante 2.7, I did. He asks, why?)
Dmitry
Juizer
Post by Juizer »
I'm also slightly interested about clear headlights. ;)
Also about the ac unit, do You have the V8, C4 or B5 unit?
I got B5 unit basicly free, but it does not fit to typ44. :huh:
Heres something about the diode mod, You did this I suppose?
http://www.hax.se/alternator/
I have the diode also, just need time to install it. :)
AudiQuattros
Juizer wrote:I'm also slightly interested about clear headlights. ;)
Yes
Dmitry
AudiQuattros
Пересеклись..
О моей машине наверное весьма весьма двоякое впечатление
Dmitry
AudiQuattros
Поставил тормоза. Притираю пока.
Поменял вентилятор печки. Печка теперь работает как ужаленная.
Заслонки все проверил.
Переварил пайп впуск. От интеркуллера до дросселя. Теперь на силиконе.
Dmitry
AudiQuattros
Поменял масло . Залил 10/60 eni/agip racing.
Давляк стабильно 2очка.
На 110 градусах 1.7. На 130 1.5.
Меня радует.
Масло фильтр оригинал.
По одометру, 355000км
Dmitry
AudiQuattros
Поменял радиатор печки и Кранчик печки на оригинал.
Спасибо Яну!
Dmitry
AudiQuattros
Новые сайленты подрамника.
Dmitry
AudiQuattros
http://youtu.be/lmAG33vv2oY
Men do not know about you, but here in Russia spare parts for our machines in the afternoon with fire you will not find! and then just very very much! who does not know where it is? So what is this? just standing machines or understand?
Dmitry
AudiQuattros
I would have took the car entirely what some of them)
Dmitry
Juizer
Post by Juizer »
Damn, sad video. So much to salvage... :nuts:
Dmitry, I guess we live in the wrong continent. :roll:
Was this a big operation?
AudiQuattros
Juizer wrote:Damn, sad video. So much to salvage... :nuts:
Yes I think so too.... after this video
before that was all original
Dmitry
AudiQuattros
weekend driven car to do the rear fenders.
Dmitry
AudiQuattros
future new color machines
We will stand out :)
Dmitry
