All torn down! Unfortunately for me, the cam bearings are shot....shit! The plan was just to throw the new cam in and forget about it but noooooooo, there has to be chipped and scarred bearings. Great.
stock cam
1986 4000cs Turbo Quattro 2001 Dodge Dakota R/T Standard Cab 1990 V8 quattro 1995 urS6
-Hersh Performance and Racing Products- Most orders are being refused until further notice. Please PM
well looks like I'm not going to change the cam bearings. Turns out I'm going to have to remove the motor, crank, rods, etc in order to have them changed. Not going to risk doing it myself and dropping a bearing into the pan. There is 0 wear, marks, scratches, or scourges on the factory camshaft journals so screw it. I won't have more than 10,000 miles on this thing when the new motor goes in anyways. The funny part is both #2 and #4 bearing have the same rectangular chunk missing in the exact same spot. Oil pressure was never an issue so screw it. I know this isn't right but I'm not pulling the whole damn motor.
AngryTaco wrote:The way I see it --- wasn't having noises, no low oil pressure issues, no issues whatsoever. (not saying it won't be a future problem but meh)
I agree with you, some extra assembly lube will go a long way. Plus by the time it becomes a future problem i'm sure you'll be so bored with this motor a nice crate one will be waiting to go in.
I've got a supercharged 408 stroker in the machine shop we are working on
Throwing a vortech v-2 on there just for reference
Yeah....should make about 800 - ??? hp on e85 and 12psi with 9.5:1 compression on Aluminum heads. The problem is....the accepted hp limit of the block is about 850. There are a few people trying to push the block to the limits with extreme blueprinting and machine work. I'm following a few people and seeing how it works out for them.
I only plan to run a 650hp tune 90% of the time. The other 10% of the time is when $$$ is involved
Started doing the port work today. Had my math test tonight so schedule opens up a little for the time being. Been getting behind on shipping peoples' stuff out.
Stock bowls
Stock Exhaust
Stock Intake
After my port work on 2 cylinders tonight. Will be doing some minor deshrouding in time.
HEADSTUDS ARRIVED TODAY!!!!! ALL THAT'S LEFT IS THE PUSHRODS!!!!!!
FRICKEN DAMMIT!!! Turns out I was sent big block valve springs and not the small block ones. OYE. However, it looks like one of those rare deals where the machine shop has some wrongly ordered Comp Springs laying around which would be perfect for my application with some minor machining. Have to deal with the place I bought them from in the morning.....great
Got the other head ported today as well. Had to in order for the machine shop to properly get both heads cut for the new springs.
Well fuck. Company will only exchange the wrong parts for the right now. Damn heads aren't going to be done till sometime next week. SOB!!!! I want to DRIVE THIS THING......SOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO BADDDDDD
Got the camshaft, lifters, and new double roller timing chain installed tonight. Everything rotates smoothly and perfectly. Bout time something goes right.
Well...found my oil leak. Turns out the harmonic balancer is completely shot and needs to be replaced. Wore a hole into the timing cover which explains the oil leak. I can't believe the leak wasnt horrendous for the size it was.
I'll post pictures later but the balancer is extremely obvious upon inspection. I'm surprised it didn't fly off honestly.
Off to the yard!!!!!
Getting a new Harmonic Balancer today and reassembling the front timing cover. If only these were as easy to adjust cam timing as the OHC cars. If I choose to advance/retard the camshaft, the whole timing cover has to come off again. Yay lol.
Looking forward to having half the garage back again lol!
