Rallyfreak202 wrote:Just asked The Architect what he thinks. We'll see.
Responded.
TheArchitect wrote:OK I cross referenced your build thread and the previous messages you have sent me.
Let me tell you what I think you have and you can comment.
I take it that the 1B ECU has its ignition 1 driver, driving a normal inductive coil and you are connected to a 5 window distributor (the 5 window item is critical).
Can you crank the engine and read RPM with the laptop software?
You say spark is weak, how do you know this and are you sure you have spark at all?
Is the ECU configured (built) for driving a normal 2 terminal coil (some units are built for a 3/4 terminal POS coil).
If you are sure the spark is weak, have you tried bumping the dwell time?
What is you dwell time and dwell degrees?
Any possibility you timing is way off?
Reading some of your thread was confusing WRT the 034 ECU, you mention removing a MAF line and the effecting the ECU running, whats this about?
Is there another "stock" ECU connected and partially in control of the engine?
Rallyfreak202 wrote:glibobbo21 wrote:AAN pan wont work
Thanks.
savagerocco wrote:Rallyfreak202 wrote:glibobbo21 wrote:AAN pan wont work
Thanks.
We have the AAN pan in out 4k turbo car. It works
my2000apb wrote:wrenching restarts, weds 10 am!
fedex express dizzy en route
ShadyUrS4 wrote:my2000apb wrote:wrenching restarts, weds 10 am!
When you gonna be back in sylva? We should hang. Im back in sylva now!
my2000apb wrote:ShadyUrS4 wrote:my2000apb wrote:wrenching restarts, weds 10 am!
huh? who are you
my2000apb wrote:savagerocco wrote:Rallyfreak202 wrote:[quote="glibobbo21"]AAN pan wont work
Thanks.
my2000apb wrote:...
pilihp2 wrote:When I couldn't get my car to start due to ignition issues it I solved it by going to new coils, wires, and plugs.
Not sure how much that'll help. But are you sure your coil is good?
ShadyUrS4 wrote:pilihp2 wrote:When I couldn't get my car to start due to ignition issues it I solved it by going to new coils, wires, and plugs.
Im with philihp2 I'd check that next. Id love to come help ya nick but isnt the car back at your parents?
extreme90path wrote:This MAY have already been discussed, but are you 100% your getting fuel? If your getting spark and timing are correct, that pretty much leaves some kind of fuel issue. Just my 2 cents.
extreme90path wrote:Is your coil good? Try swapping it with another? Are you getting a full 12-14v @ the coil?
