Who is planning to come to Carlisle this year?
Meet and greet
With March soon apon us, Carlisle will be here before you know it. I know Mike has started getting ready, and I know of a few others as well. Who else is planning to come? Last year's event went well, despite the combining of the 2 shows. I'm looking forward to seeing you everyone again this year.
Grillage
Re: Who is planning to come to Carlisle this year?
Post by Grillage »
I am! Bringing the B4 this year.
CURRENT
PAST
oil_me
Post by oil_me »
I'm planning on being there this year. Not like my uh no-show last year.
'91 80Q m-TDI DD 51.8 mpg-"the oil_can" http://www.theprojectpad.com/viewtopic.php?f=11&t=1529&start=175
'89 80Q shady 80
Sparkyjack
Post by Sparkyjack »
I'll be there!
After dropping my stuff off at home last year I went out for lunch in the coupe, it died on the road.
I flat beded it home and spent the rest of May and most of June figuring out what happened, replacing the gear and then getting the timing right so that it would run.
Since then I've had the replaced the front Comtrol arms with forged ones, the rear subframes with a late model one that has sway bar mounts I also got all that and the shock towers powder coated. I've swapped shocks and springs twicce and cleaned out the oil pan.
I'm now in the middle of replacing the rear speakers and adding keyless entry.
First alignment was clearly done by a monkey, second alignment (by an Audi enthusiast) resolved a bunch of quirks.
I need to finish up the speakers, keyless entry, glue up a piece of plastic I broke and do some other more minor stuff.
I might just make it if I burn some PTO.
Jack
Peters
Post by Peters »
i had a similar issue with my black coupe..turns out that all the issues were due to a bent front subframe - My mechanic (Lee Malo - Advanced Technologies in Gloucester MA) spent a lot of time measuring the subframe and ball joint/control arm spacing. We ended up replacing the front subframe and now the car tracks true
gabriel.b
Post by gabriel.b »
I want to go, probably in the RS4 though
Post by AudiSport4000 »
I've been slackin. I'll be there fo sho. I'll get a thread up soon!
Fattyalx
Post by Fattyalx »
If I get my megasquirt done, I'll be there in the 200!!
