...I wonder if htat is the interference...
The shield definitely needs to be grounded somewhere. If its floating it can be acting like an antenna and be noisier than an unshielded bundle.
audifreakjim wrote:I get the same activity on my flywheel trigger, the common component is the old VR sensor. I should try the new one that came with the 6-speed. I didn't use it because I didn't have the female plug to match it.
cbrydon wrote:...I wonder if htat is the interference...
What was the difference on the new VR sensor? Just the plug? I have looked at my VR sensor as being suspect as well. I'll throw a new one on, and ground the shield dto pin 8 on the ECU, and see if that helps at all.
ShavedQuattro wrote:audifreakjim wrote:I get the same activity on my flywheel trigger, the common component is the old VR sensor. I should try the new one that came with the 6-speed. I didn't use it because I didn't have the female plug to match it.
Thanks Craig
I was doing assembly as we went !!!! I started the day without tail lights, seat belts and headlights hehe..
