highlander69 wrote:Looking great !!
I'm planning on putting the alternator on the passenger side also.
looking forward to updates
Yeah on my urq I put the alternator lower left and PS pump lower right and it makes for a really sweet setup , but with this engine there is a little more room so more/different configurations can be obtained .
For example front mount radiator in B2 without even cutting the core support , like Sean’s has. I think Jimolde has that same setup too.
So lots of options or ways to go really. I don’t know if you plan to do dry sump but that takes a little of the space.
Now that I’ve got this intercooler and trying to do a sweet low piping , less bends setup like Jim’s and the old Audi sport cars did, it kind of rules out the front mount rad unless I go in front of the intercooler which would likely still be a possibility if I needed it to .
I can’t be that far off, though, because for example here is the stock rad for comparison. If I go with a super tilt it would fit - not planning on using it but I think that going just a bit smaller will work as long as I can get some sizable fans and ducting to go in there.
I guess I should think about it this way.
I have two options,
Option 1 , "Fab" a cardboard box down to size and figure out exactly how big of a radiator I can get on the side there and start with that/
Did the sport Quattro have a notch in the frame rail where the radiator sat?
Option 2, If I want the alternator out of the way I can't move just the alternator, (I believe?), due to the belt setup. So in that case I would , move the alternator to bottom left, and go electric MR2 power steering and Electric water pump. Good option , requires some re work, no big deal. But If I ever decide to do a dry sump I wouldn't be able to put it there then.
Option 3 Audi sport alternator in the back seat
